No balance function… my search goes on…
Yeah I just sold two of them because they didn’t balance
12s?
balancing?
obtainable?
you have my complete attention, Sir…
tell me more!!!
STAT
It’s got enough pins to be 12s
already there!!!
tanks meng!
12s, small, balancing and have canbus. Not possible to order yet but in a few month i think it is
July, 2020.
Still no compact options?
Flexi
Not for sale yet, only tester units as far as I understood.
The smallest ones that actually balances for 12s I have found is the 50x63x11mm red potted ones. For 10 and 13s there are slightly smaller units around that balances. Fuck skateboards I guess.
The smallest 35x63x11 does not balance. One of my packs is out of balance after a few months. Not a big deal though as I can just top the low ones up. It stops the charge when the first P-group reaches 4.2 volts so the rest will be below that. So you wont see any fires caused by over voltage when charging so that’s good. After maybe 500-600km my 12s4p 30Q pack abused with previous antispark fires and stuff had a diff between low and high of 0.11 volts so a decent amount. Running 90a battery max so another pack might not drift as much.
That would be flexibms
Someone with the bucks to spare, please take a daly 12s bms and sand it down until you you reach the pcb. Or find a way to melt the rubber plastic it’s potted in. The highest points on that pcb should be the mosfets and the jst port
Well, heatsink’s beefy as well. I wanna see the barebones height lol
Are these for sale yet?
