it was at this moment that I realized that you can have somebody more stupid than me
Some of the cheap ass escs work with 12S or it was a fake video i watched idk
Oh nevermind it only worked when he had a lower voltage on the battery
Bruh he donât know lol
The answer is no
If you plug the ESC into an over powered battery like a 10s4p of p42a, nothing will happen. It will still pull as many amps as it needs, it wonât fry itself
If you plugged a 10s esc into a 12s battery, then youâd have some problems
However, you may see a performance increase in terms of range. The p42 would be barely âworkingâ with a 30a esc attached to it haha
Apparently 11 days was the correct answer. Maybe. If it doesnât break right away
So itâs done? I need to see some wheel spinning if we are calling it
i demand some burnout videos, lets also not forget about the waterproof test
Toss it in a river. Ride it for 5 km. Put it in the closet for 3 days and donât touch it. Take it out, if it goes 5 more kilometers then Iâm impressed.
Itâs that closet sit thatâs a killer.
link to build thread btw
Low Flow | Bustin Eq 36" | dual hubs 90mm | 10s4p battery | Basic Esc - DIY Builds - esk8.news forums
What kind?
the one inbetween the enclosure and the deck is some soft foam that came with the enclosure, the one sitting around the components is hard packaging foam that came with my gpu that ive reused
Are we going to get this to an argumentative 500 so homeslice can get a name?
476
I refuse to post here to support something as silly as that!
OhâŚwaitâŚ
The countdown continuesâŚ
count me in this historic moment
20 ten char
19 ten char
