Threadlocker hack
Any thoughts on using nail polish instead of threadlocker if you have no threadlocker or loctite lying around and nowhere to buy it on a Sunday?
I just tried it now on some bolts while waiting for my loctite to arrive. Hopefully nothing bad happens :slightly_smiling_face: plus loctite is expensive, nailpolish is free :grin:
Depends on what are the bolts holding imo :smiley:
Do you also use olive oil when you’re out of lube? :grin:
No threadlocker needed if you just start the screw at a 30 degree angle and apply a lot of force when starting it.
Don’t do this
These are the bolts, I think they are steel
Only when ur mother pays me to :joy:
I mean I used epoxy one time, needed a bolt to stay in a oversized bore
Nail polish sounds a little iffy to me. Locktite is not expensive when it comes to safety. That said, a few wraps with Teflon tape can help temporarily.
Yes, it’s only temporary, I seen several people online use it as replacement:
