Okie Dok. Time to unveil what a lot y’all have already been seeing. This is my big fast af boi. I’ve decided to name it Dream Chaser because of several factors.
Anyways, it will be boasting a 20s6p with P42A cells and controlled by twin tronic 250’s. I plan to throw at least a front binding on if not both. It has @Skyart 135 kv 7490 motors and rocks a 9:40 (4.4) gear ratio. The wheel sets are both 200-215 mm (8-8.5 in). The drivetrain is all from @3DServisas and is the finality setup anodized in blue. The deck and enclosure are both from @tomiboi and are very big and wide for my fat ass. I’m planning on running as much power as possible through this system for esk8 con. At the time of posting this, it is programmed and almost ready for its maiden voyage but I still need to finish up a couple things.
Specs:
20s6p P42A (180amps battery total)
Tronic 250’s (250 motor amps each side)
Skyart 7490 135 kv
Finality 4.4 gear ratio on 8-8.5 in tires
Lmk what y’all think so far!
