Hey I’m super tired, it’s looking like these evolve pulleys don’t fit tb 218 trucks am I correct. If so I’ll just get Bkb thanks guys
Evolve pulleys are designed around an 8mm to 10mm stepped axle. If you use the 10mm bearing on a tb truck then it will be too big and you probably won’t have enough axle. Might be the same story with the bkb. TB pulleys bolt onto the wheel without a bearing so don’t take up any axle space. Check with bkb the compatibility before you buy.
Aight thanks brother appreciate it I know the Bkb ones work
Yeah just checked and they are spot on depending on motors. The very max I can get between the motor plates while still being able to run the axle nuts the right way round is 175mm. This will just allow 2 sk3 6374’s to sit without touching. They are big cans though.
