Hold on a sec. Do you try esk8steel?
Why can’t bestech use simpler bloody names for their bms’s?
BMS’s is bad enough already. You are never sure when you are done saying S’s. See what I mean.
Bit like banana. I can start spelling but struggle to stop spelling it
Banananas
Oof. So glad i don’t need it.
Don’t set him off or he will show you his other penis compensater.
Why can’t someone design a decent one of those POS rubber thingies that go in your charge port when you aren’t charging? They are annoyingly hard to get in and most times when I charge I find it fell out anyway.
I’m considering this:
I used the 3 pin of that, I like it I got the 3 just so it’s totally impossible to force it on backwards
That’s a good idea.
one tip… make sure you ‘fix it’ tight to the enc, I kept on unscrewing from the enc by accident when i should have unscrewed the charge part.
The GT2B is a transmitter with two potentiometers on different channels.
Why hasn’t someone designed a mod for it that uses both a thumbwheel AND a trigger (not at the same time of course)?
Why shouldn’t you tow hummie hubs 40+mph? 60v Back EMF can smoke a vesc.
I think becasue the thumbwheel doesn’t have much throw to it? It’s also in an awkward place if you’re also using the trigger but a case mod can fix that.
I got these fellas, smaller outer diameter. Would recommend.
https://www.aliexpress.com/item/32419570148.html?spm=a2g0s.9042311.0.0.396e4c4dN85rzN
They should have an indent to stop that from happening, mine did anyway
JB Weld 8265-S Original Formula to the rescue
Why can’t the VESC implement transient suppression and not use international rectifier crap XD.
