On a cart track then I would be going wide as urethane over numies. To get the rolling resistance down then you have to have your tyres so hard you end up with very little contact patch. With wide urethane you have a nice area of grip so long as they are warm. This also depends entirely on the track surface.
You need something in between like a cart tyre. Oh hang on.
stooge race wheels
Hey man, if you’re going for thane, I would rock 78mm venom Magnums, with pulleys from @moon. That’s the urethane race wheel that is killing it right now
Shoulda let you ride this. For me it worked really well and @esk8manbabes rides something very similar and I think he does pretty well over in the Belgian/Cloggy cart track?
I would also say AT vs thane is probably a rider to rider thing. Some might like the initial rolling resistance of AT as it’s similar to engine braking, it can help you feather it at the top end of your limits through a turn. Whereas some might find they’re skilled enough through turns to flat out hang on to the edge of a board and slide. Those folks prob should go with thane.
Drop the idea that sliding through a turn is some how faster. Grip is paramount for maintaining turn speed. You are only as good as your contact patch. Thane is no good for grip.
I’d definitely go TKP over DKP if you are looking for a turning advantage over RKP but wish to still maintain stability for the straights. You could even try a TKP up front while keeping an RKP in the rear to see how you like the feel
Bindings are not always the answer… Moja absolutely pulvurised every trampa rider (including the Team Trampa folks) in Paris last year on the AT (underground) track riding a Streetwing P1. It helps knowing how to move and position your feet on the board.
