The magic smoke came out of my Xenith :(
I’ve had a small 6S board working on and off in various states for a few years now, powered by a Focbox. A few months ago I decided to make a much larger 10S board and bought a BKB Xenith from Ben Buckler Boards here in Australia.
Today I finally got to the point of plugging the battery into the Xenith. I very carefully checked the battery voltage - exactly 38 volts. I very carefully checked that the polarity was correct. I held my breath and plugged it in. No sparks, no smoke, no pop. I pressed the included on/off switch and lights start flashing in a promising way.
So I brought the board over to my computer and plugged it into the USB. Windows detected it and I opened VESC tool 3.00. I was just wondering why it thought the Xenith had a newer FW version than VESC tool supported when I heard a quiet pop from the Xenith.
I unplugged things as quickly as possible, but before I did some of the magic smoke came out, which as we all know can’t be put back in once it escapes. Feck. Well I guess I won’t be building this board any time soon. I do have like a dozen other projects waiting to be worked on though so not a huge deal :stuck_out_tongue:
Upon removing the heatsink I was immediately assaulted with the most intensely vile- and poisonous-smelling melted-electronics odour. After I recovered and made it back into my room by holding my breath, I managed to get a photo. One of the DRVs is totally toast. Absolutely no clue what happened here. I’m just hoping BKB or Ben Buckler will be willing to do a warranty swap; I hadn’t filled out the warranty form since it requires a photo of the installed Xenith and I hadn’t gotten that far yet :neutral_face: Australia has fairly strong protections against stuff that’s DoA or not fit for purpose so I guess it just depends whether it really was DoA or I somehow killed it. I was extremely careful not to allow any soldering or wire-stripping debris anywhere near any electronics (including the Xenith) so I’m not sure what caused what I presume must have been some sort of short.
Anyway I just thought people might be interested to see yet another dead DRV. I’m still comparatively new to the esk8 space but from what I’ve seen, popped DRVs have been a long-running feature of VESC-based ESCs.
Those are the pins on the stepdown regulator.
This might be a DOA.
This indicates firmware corruption.
power glitching from a faulty DC-DC converter can cause firmware corruption.
My guess is cold joint or something else caused the buck converter circuit to misbehave. This caused firmware corruption and eventual device destruction.
I believe Xeniths ship with the legacy Unity firmware. That’s why the VESC Tool 3 would report it as incompatible. Since the legacy firmware version is something like 23.48 (which is a high number), it may just as well be reported as “newer”.
However, this definitely has nothing to do with the magic smoke.
Sounds like the vendor needs to take action
The melted part is one of the DRV chips. Are you saying those pins are connected to the step down regulator elsewhere on the board?
It was indeed a number like 23 dot something. My assumption was that it was some weird old version and I was just about to flash it to the VESC tool’s included Unity firmware to make sure it was on a valid firmware when it went pop.
The vendor will if I have any say in the matter lol.
The stepdown regulator is in the DRV
Ah, I considered that possibility but I’m on my phone and didn’t feel like looking up the datasheet for those chips to see.
