Pretty low to be comfortable
Came here when I saw “The GT40”, was not disappointed, am now leaving with a smile on my face. Thank you for the gorgeous build.
I appreciate such good vibes, thanks @Vanarian
What kind of config would you suggest for the GT40? I noticed that they have a lot of options for flex and extra layers of composites.
I like the carbon fiber layer, everything else should be optional according to your preferences
What size riser are you using @eBoosted? Also m4 or M5 inserts?
M5 inserts all the way
And the risers?
Edit: seems that you are not using risers at all
No. I’m not using any risers, I upgraded to Trampa urban threads and the ground clearance is pretty good. I’ll send a picture later
cool build man,nice work!
but i reccon you should swap those motor mounts around… the idler should be on the slack side of the belt. on your setup it will not be very useful and bearings would die quickly
Yes. That’s 100% correct, I’m gonna swap the idlers as soon as I can
idlers all the way (:
