Yes. They were made out aluminum and cut and detailed by hand
Yet another beautiful build @eBoosted Hats off
But ur Unity with 30T 140A combo sounds promising.
What kind of range u expect? 15 miles riding hard~ish?
U gonna run 18-60 gearing? What length belt are u using?
Amazing, just as all your work @eBoosted . Not to be that guy, but why are your Idler pulleys upsidedown? LOL, I mean to ask, why do you have them on the drive side vs the brake side?
Thanks @PatRocks, to be honest I didnât know there was a brake and drive side for idler pullies. I mounted it underneath in order to have a bit more clearance, but the decision was mainly aesthetical, no idler pullies on top makes the drive train look cleaner. The good thing is I havenât experienced any belt skipping even with the belts loose at really hard braking.
The board range would be 35kms according to my calculations, I havenât run such long distances yet though.
Gearing is 18/60 itâs perfect to get 55-57km/hr and the acceleration is nuts, you really need to try such a high discharge to understand the acceleration and smoothness. Hard to describe.
My belts are 425mm, perfect for this combo, I used bbman calculator
How thick are the plates?
The plates are only 3mm thick
@eBoosted Your thoughts on Century vs. Switchblade?
I canât choose between the two for the AT build
Hi speed stability: Century. Not much room for motors unless you make custom longer motormounts and install them outwards.
Amazing looks: Switchblade. You need to move the trucks outwards to allow pneumatics, easy task, not much ground clearance if you mount the trucks drop through.
Both are the decks I had more fun with between all decks I ever tried
Riding on the bikepath
You stole my next boardâs name!
So I met a guy who has a Winboard and we went for a ride around Barranco, Miraflores and San Borja in Lima PerĂș
Here is the video from yesterday. Enjoy!
Yoo Bro!! Watch out at 0:25 sec. you against the wayyyy Alannn!!
( Nice vid as usual thou
Aaaahaha nice slowmo!
How many miles/km was that? It looked like there was no sag throughout the video at all :0
This was roughly the route:
24.4kms, I got with 30%, total range should be 35kms at full acceleration on a 12s4p made of Samsung 30T cells.
Canât say enough how happy Iâm with this board right now.
Thank you!
Can you please post a METR graph of a ride? Doesnt have to be the one above, im just interested in comparing general performance.
now you got me interested in this deck/enclosure. Will this combo be too low with 107mm wheels?
In drop though yes (too low), top mounted it will be high enough, but still a pretty low ride, like Alan has. DKP trucks probably work in drop-through, after all Evolve run them that way.
