Not necessarily. You could just have a single cell that is slightly higher than the rest in that group causing it to over charge. @ that point you’re pretty much fucked if you want to fix it. You’ll have to pull group, find the over charged and bring it down. If you dissemble then I check every last cell.
I dont think those generic charges have that capability. I could be wrong but most generic chargers I’ve opened dont have one. Just my experience
This one does (/should) i have the same one, just in 10s.
I have set mine to 41.8v but i stop charging earlier manually.
I checked the output before, it is 50.4V
Dammit, it is actually possible that there was a slight variation between cells in those 2 groups but I thought it wasn’t significant enough to be an issue. And for some reason, that they would balance out when connected in parallel, I don’t know why I thought that tho
Can I “solve” my problem by charging to 49.xx or something? If this is the problem I have?
I’ve seen this not happen more times than I’ve seen it happen. You would think they drift balance between themselves but again, I’ve rarely seen that happen. Especially if there is a difference greater than .05.
Dammit, here is what I get assuming shit I have no experience in .
Yes. If you want good life from liion, it’s good practice to do 20/80. Dont discharge below 20% and dont charge over 80%. I tend to go 30/90 but that’s me. Nothing wrong with limiting the max voltage.
And in doing that you may get lucky and it semi balances its self out. No guarantee though
Mistakes are made to learn from lol
Alright I will do that next charge.
Just to be clear, 0% on a 12S battery would be 30V 100% is 50.4V so 80% would be 46.3Volts right?
if you want your pack to last you, the furthest you should drain to is 36v, i’d personally recommend 38.4v for the best longevity (3.2v/cell)
That being said, 80% is not 46.3v as the voltage curve is not linear. 80% is closer to 47-48v from my experience.
Just charge till the highest cell is at 4.1v
No damage done
these numbers like 30/90 are confusing with liion. i think we should just refer to cell voltages. I discharge my cells to 3.4v (at most) and charge up to 4.15v
For me I discharge to 3.2 end cutoff, seems to be good for me.
i dont like hard cutoffs incase of emergency. my hard cutoff is at 0v, but my soft cutoff is 3.3v/cell.
I have metr pro so if I need more I can always just reconfigure on the road
Well they will equalize (all the cells in each group will end up at the same voltage/state of charge), but whatever that average point is, isn’t guaranteed to be a direct linear math equation, since the discharge curves aren’t linear.
I still think it’ll probably all end up nicely balanced, it’s just gonna take a bit for those last few cells to get in line.
If things haven’t improved in a day or so, then I would consider manually charging/discharging the appropriate p-groups to bring them all within <0.05 volts of each other.
I will rebuild my board this winter, for next season. And i wont be able to ride until maybe april next year.
Winter is coming soon here. It will rain, be cold, and snow pretty soon. Maybe a couple sunny days left.
So. If i take my batterypack out, disconnect it from the esc, will the cells be at the same charge as now when i reconnect it? And at what voltage should i store the pack in? 10s4p 40t3.
