I assume so…balance charging usually happens when a certain set of criteria are met with regard to pack and cell voltage, so I can only imagine if those criteria are met before and after the unplug/replug, it’d continue as it was.
I could be wrong though…but I no longer leave PEVs plugged in overnight or when I’m not home.
No, but no electronic system is perfect. However amazing something may be built, they’re built from inherently imperfect things. A phone is one thing, but a large battery with a kilowatt of energy going off in a home housing a family and children isn’t something I’m willing to risk at all if possible. Charging is one the most dangerous states a battery can be in, and so I only do so when I’m around to supervise.
Is anything likely to happen on a well made battery? No, not likely. But nothing’s perfect so I don’t do that anymore.
something like a dog crate plus the fire resistant bag makes sense to me. room for two super heavy mtb in the bottom and maybe 2 boards above. then rack for other boards above that. hell maybe if it was secure/dry leave it outside depending on your property.
Rather then store the entire board in a metal crate while charging, it may be easier to design batteries to be removable. At least with top mount boxes, we’re not far from that now.
Normalize removing batteries for charging (and put them into a fire safe bag and/or metal cabinet)
Even lower cost of failure. Don’t risk your board or your house.
Metal wall locker in the garage with no other boards in it while charging with a 120v smoke alarm inside that is hard wired in series to the other alarms inside the house.
