Hey all, and thanks for the amazing resource.
Before Iâd found this place I ordered an Ownboard Carbon GT.
Sooo Iâm committed to it now and it will arrive next week.
My question is, is it feasible to add a vesc, and dismantle the sanyo ga 10s4p battery that comes with it, and rebuild it as a 12s3p?
Wouldnât this mean it would only be able to max at 30A instead of 40A, but at the higher voltage?
It would also decrease the range a little too if Im taking out 4 x 3000ma batteries right?
Is it worth bothering with, or just ride it for a while until I can find somewhere to but 40t cells in Australia and build a 12s3p from those so as not to lose max current?
Thanks in advance, I did search for reconfiguring a battery like this but didnât see anything sorry if there are many posts like this
Welcome to the forum @Clunt
Is there reasoning behind you wanting to go higher in voltage while losing in capacity and range?
As for finding batteries in Australia, paging @glyphiks
@Flasher I was looking for more torque and top speed. I know I can have one or the other with gearing but wondered if by going up in volts, I could get a little more of both? Or does the reduction in Amps mean less torque?
If so Iâll just have to wait till I can afford to go for the 40t cells in a 12s3p config
Do a 12s3p P26A or something
In any motor, the basic principle is very simple:
rotational speed is proportional to voltage applied
torque is proportional to current pulled
The 12s on the motor can take more volts, if all else is equal, it can give you a higher maximum speed.
But the difference in voltage does not affect the torque. To get more torque to go up a hill, you need to supply your motor with more current. A motor that can take more current (and a battery and motor controller that can supply more current) will give you more torque to help you up the hill.
I think you will still enjoy the board as is. Youâll eventually grow out of it and want to go down the rabbit hole. Save your monies for when you do
Also, having an unmodified board means youâre almost guaranteed to have something to ride while you have fun building your dreamboard
So Iâll wait for the 40t cells for sure, cause I wasnât really wanting to drop any torque.
That was exactly as I expected, but then got confused as someone somewhere else posted that watts is watts⌠thanks again ( apologies for the deletes, kept posting before Iâd finished on my phone)
And I might have a play with the vesc setting to see if theres any more available in the battery/motor. Once that gets here, Iâll put everything to what the motor/battery can take and see if it was bottlenecked any from factory
Well yes thatâs kinda true. Equal watts is equal watts when all else stays the same.
But
W=A x V
So 10s4p is 40a x 42v = 1680watts
And 12s3p is 30a x 50.4v = 1512watts
Not all watts are created equalâŚif you take a board and bump up the voltage but donât go any faster you donât get more watts
That would usually mean something is acting as a bottleneck no?
I meant if you choose to not go faster, I will not go above 30 even if the board could do 50 so me bumping voltage does nothing (same current would be same torque)
Damn dude, Iâm coming to you when I need nickel soon. Youâre right near my parents
OhâŚno idea what that meansâŚyou mean some like to be snails on powerful boards?
I mean some people might, I just gear them down
I only have 12s boards. But theyre both with different gearing so I get to decide if I wanted torque or speed.
15/42 trampa speed demon
15/62 mbs electrified monster
Next build will be 4wd so I have both
Edit: I lied, I have a 10s board but itâs just gathering dust
I have a 10s because legacy parts
Soo, if you had this 12s3p, youâd expect it to be capable of a higher speed, but with less torque?
And if it were a 12s4p same cells, youâd expect higher speed, same torque or more? Amps hasnât gone up going from 10s4p to 12s4p, so does that mean same torque as 10s4p? Or because its higher watts, it would have better speed and torque? Thanks for your replies, mucho gracias
that is my understandingâless cells, less torque. @MysticalDork has a better way of explaining this than me
