The battery builders club
Help with charging please :pray:
Problem, newly installed D140 BMS not charging.
Went on ride with a fully charged 42V battery on a 10s4p pack yesterday.
Installed volt meter showed Battery at 35.6V, plugged in my charger and noticed the green light on charger stayed green. Left it on charge for ~ an hour, battery still read 35.6V.
Did some measurements:
  • Charger output is 41.8V (not connected to charger port)
  • Individual 4p pack read 3.4 to 3.6V, 1 pack showed 3.4V with the rest between 3.5 to 3.6V.
Are the voltages between packs too large (0.2V) for the BMS to balance? or my BMS shot?
This sounds suspiciously like it’s the same cause as your other BMS issue. As if the BMS is in protection mode. I still think the most likely issue is some contact problem with the balance leads. Might even be miswired?
Can you measure voltages at the JST-XH connector, with meter positive lead connected to pack (+), check voltage with the meter negative lead at each contact? Looking at your diagram it looks like 10 wirres for 10s, with shared +. so contact #1 should show 0v, contact #2 should show 3.5v, and so on.
If that’s all good, can you check if you have the order correct for the JST-XH pins? Maybe you have them reversed?
Also with charger turned on and connected try reading voltage at pack +,-. Compare to resting voltage. It should go up slightly. If it doesn’t the BMS is probably in some protection mode.
Comments concerns on the welds?
I plan to add silicon between the cells. Something with a nice thermal rating? But mostly for mechanical support.
I also am planning.on doubling up the strips.
Dual 6374 in a hilly environment should draw good amps.
Some look a bit overdone; this document has a lot of valuable info.
Just for lolz, has anyone ever tried this? If your spot welder can’t handle thicker nickel and you don’t want to weld nickel to nickel, maybe this is a viable option? :stuck_out_tongue:
Found the problem
apparently, silicone based adhesive that I used to affix BMS to the enclosure caused it to short, went in protection mode.
After cleaning the adhesive, BMS is working fine now.
Thanks for the help :slightly_smiling_face:
Silicone is conductive until it cures.
After it cures, conductivity depends on the particular type of silicone used.
Silicon was not completely cured when I removed it, probably the same thing happened with my previous BMS.
You shouldn’t have silicone sealant in contact with electronics anyway. Even neutral cure silicone is conductive since it has lots of moisture before it cures.
Not to mention that silicone absorbs moisture.
Good to know, what do you use?
I usually cover the BMS in heat shrink first then secure on the enclosure.
If I fear there will be any sorts of rubbing, I add fishpaper too.
Liked your method with heat shrink and fishpaper :ok_hand:
So you would still use silicone but cover first? Honest question from a scared dude who just uses silicone on everything
So I got this nickel strip form nlon.nl
https://eu.nkon.nl/accessories/battery-solder-strip/nikkel-batterijpack-verbinding-soldeerstrip-27mm.html
It’s advertised as “CHEMICAL COMPOSITION:NICKEL ≄99.7%”
I still was curious and did a salt water corrosion test. It started to rust after a day. hmm :thinking:
Now the weird thing: I can wipe away the corrosion and rust with a dry paper tissue and the strip looks like new!
(and no, the pics are NOT before I did the test)
So WTF is that “pure nickel” strip made of???
I’m thinking, if it’s nickel plated steel I couldn’t just wipe of all the corrosion?
Oh, and should I use it?
How does the voltages look on these pack, do they look to high or low?
The 3.65 one is a little bit low, the rest are all pretty within reason for a balanced pack since they are (±0.01) I think people are fine with ±0.05 but I don’t know for sure
And obviously by the battery indicators they are at like 65% charge
#5 is low but not as low as your phone battery :wink:
Could be metal dust from manufacturing that’s rusting on the surface.
I found the cause for the discharging first P-group in my pack.
The transistor in my BMS that is responsible for that P-group has low resistance.
I basically had around 4,7 kOhm slowly discharging my P-group.
I need some help guys. I have x4 Li-Po’s that I want to use on an eMTB build. I would like to combine 2 in series, the 2 series in parallel. I have the POS & NEG structure defined, but Im at a loss as to how to connect the balance leads. I haven’t done a lipo build in a couple of years and I don’t wanna make a mistake. Any help would be greatly appreciate.
Each individual pack has the following voltages per lead.
PACK NEG (BLACK)
Cell 1 = 3.7 (YELLOW)
Cell 2 7.4 (YELLOW)
Cell 3 11.1 (YELLOW)
Cell 4 14.8 (YELLOW)
Cell 5 18.5 (YELLOW)
Cell 6(?) 22.2 (YELLOW)
PACK POS (RED)
There are 4 of these packs, given that each one connects to its neighbor in series to make x2 12s1p groups then connects in series to make a single 12s2p group, how do I connect the balance leads to the BMS?
