The battery builders club
Thats what I was looking for thank you so much.
I messured the voltage
Seems like a dead cell in P1
what bms are you using?
0.2V difference is quite big. Maybe bad bms?
Or B1 could be draining the other cells?
D140 BMS
So not a bad bms
I think its the cells
Where did you get the cells?
Have they been reused?
There the P26a cells, could have been no clue got them from IMR
You like to play with fire dude
Yeah, Im planning on ordering new cells today, just dont know which ones I want yet.
30q? 20700b? What else is there
Ive been practicing my fire bending so im good
2jebXI0k0HLFK
Funny you mentioned this. I was just doing this last night for the new pack I’m building.
I’ve realise that I might be missing something.
Refer to the diagram I posted:
The switch I’m getting is from @Kug3lis (https://shop.3dservisas.eu/products/fatboy-mini-sparky-switch-50a-200a-100v-pre-charged-anti-spark-switch-with-push-to-start) and my assumption is that this is fine to protect the VESCs when turning on the board. However, what about when I want to charge? I was thinking that I can mount a XT90 anti-spark port to the boosted enclosure and that should suffice, but it’s gonna be really tricky and not very slick. I would prefer a barrel charging port, but those aren’t anti-spark, are they? If I wanted to use a barrel charging port how could I make it anti-spark? Do I even need an anti-spark port for charging?
What’s the best place in the US to get a dozen Samsung 40T cells at a sexy price? Preferably with some nickel too
Edit: or something similar (4000mah and 30A)
I like useing liion wholesale but there prices Aren’t the greatest and there currently our of stock on the 40t.
ordered 72 40t cells from imrbatteries for $6.62 a cell shipped. that’s volume discount tho, a dozen will be $7 per cell plus shipping.
It’s all good , you don’t need an anti spark for charging if you turn the charger on before plugging it into the charging port. Only if the charger is unpowered then it will spark.
Just had an awesome idea for those who use battery pcb’s. I’ll try to mock it up soon and share it with y’all!
This is awesome! Editorial comment: When talking about form factor I think you mean cylindrical when you say spherical.
@rich You’re shitting me right? God fucking dammit…I wasted so much time soldering xt90s to my chargers :confused:
Generally, it’s charging the capacitors that causes the spark. As rich said, if your charger is unpowered, there’s a difference in voltage (~40v on pack side, 0v on charger side). If the charger has some capacitors on its output, there may be a spark.
So, you don’t need an antispark, but depending on the charger, it’s better to power on the charger before connecting.
(BTW I fried 2 smart BMS this way, saved a 3rd one with a charge port fuse)
