Tenka is just a handicapped unity. Will only work on fw5+… or unity fw
Thanks for the quick replies.
If I bootload, it stays on the 23.46 version? I tried many times to upload and it always times out.
I also tried to download the firmware without any results. I really don’t know what could be the issue. A brink vesc?
that may be the issue. I will try with an older vesc tool version. thanks.
It won’t work. You need firmware 5 or above.
Also have you tried connecting via usb? Or has that been castrated from the tenka as well?
Bluetooth firmware upgrades are difficult at the best of times.
Yes I have tried with the USB without any results. I have tried with ackmaniac app but my esc won’t connect.
These threads may help
+1 on the second link
Sometimes the VESC tool won’t upload the firmware, and I’ve had to use one a ST-Link to manually upload it.
So, the problem is the bootloader? I just want to make sure. I keep on getting timed out when I want to upgrade the firmware.
Grrrrr.
jpo tenka ya money. ive never seen so many threads on problems with any other esc.
The Tenka is made by a guy who is known for ripping people off and making low quality stuff… so it’s possible the unit is just junk
However, I have been unable to connect to a vesc 6 with the vesc tool over usb, and loading the firmware via a stlink solved that problem.
Yup, trash product from a garbage human.
tenka is potted, OP might have a hard time just to hook it up
Good to know. I will not buy again.
The right pins are in the weird mini-dupont thing
Looks like the SWD port is a black port just above the white JST connectors.
This link that glyphiks posted above should show where to plug it in, as the Unity and Tenka are basically the same thing.
I have manage to connect ST Link. I did all the steps but it is still at 23.26 version. When I finish uploading the firmware, the Tenka stops right away? I have to unplug and plug the battery to turn on again the tenka? Thanks.
Just to be clear, this is the workflow you followed?
- Tenka connected to nothing. No battery, no motor, no USB, nothing.
- Plug in ST-Link’s 5 pins. 3.3v, SWDIO, SWCLK, RST and GND pins
- Plug in ST-Link to the computer’s USB port
- Connect using STLINK Utility. Should get a bunch of data when it connects.
- Load the “VESC_default.bin” unity firmware/bootloader file from Vedder’s github into the STLINK Utility
- Click “Target → Program & Verify” on the STLINK Utility
- Click Start. It should take a few seconds to upload. After it finishes wait 30 seconds then disconnect the STLINK from the Tenka which should power it off.
- Plug in the battery, hook up to USB and it should be the latest firmware (5.2 as of this post) in the VESC tool.
IT WORKS!!! thank you a lot!
