Temu motor especial
Hey guys can anyone tell me what I need to be able to put this motor on a board annd go. I want some harder wheels so I can slide a bit. I’m just not sure what I need as far as hearing it goes…I think they are 6374 170kv temu special. I got them both new for like 65$ I’m trying to
Enclosure
Battery
Vesc
Remote
Trucks
Wheels
Motor pulley
Wheel pulley
Belt
Motor mount
10mm shafts? Pulleys are a bitch to find for 10mm shafts. Good steel ones anyway.
Yes am in need of some rn hard to come by
I have the board and battery all the rest hangers and trucks I just don’t have what the motor needs to make the wheel spin so I need to be looking for 10mm motor pulley and what else?
Ummm… belts and wheel pulleys unless your thinking about gear drives or chains…
But D-cut shaft generate just problems. Anyway You will find some pulleys, nobody will guarantee that will fit on it. Each producer doing it little different. It is not standardized like keyway groove. So most probably You will tune it by some drilling tool.
looks like @dickyho still sells them on ebay.
Dat guy
I forgot about him
Thanks
Ok yeah I’m see what you’re saying. I made this question without enough direction of
What I was actually trying to figure out so I found a pulley which I guess that’s what it’s called that I needed. I didn’t know that so I found that I got 10 mm D cut from m boards
Although it could take a minute because for some reason, they’ve been sitting on my packages and they still haven’t even shipped me t’s been over a week
Same with my gear drivers with been over a month with those so I was like I got scammed for a minute, but I’m guessing it just takes a while Handmade type shit… Ok one more thing
Does anybody can you tell from the picture? Is this hub motor ready to go? Does it have a tire on it or is that not the tire it matches the front? I’m just curious.
