Since I am in Uni I just don’t have the time I used to. Because of that I want to start finishing projects and not create new ones. These parts I have accumulated over the years. I really enjoyed building esk8’s but its time for something new. So I will be staying on the forum but I will fully focus on trying to build a Onewheel . I will of course continue riding my esk8. Everything is excluding shipping and will be shipped from the Netherlands. Or can be picked up for my fellow dutchies.
All prices in EUR except when mentioned differently
PS if any of these prices are off please tell me thanks in advance.
Item 1 Description: Landyachtz 40’ longboard with kegels
Images
Item 1a Landyachtz Switch 40’ 2019 version Description: Honestly one of the best esk8 decks. Super stable at high speeds and the curved up corners make sure you won’t slide off your board. The drop down also helps a lot with foot placement so you will never have to look down if you are standing correctly. Price (EU): 100 from (160)
Item 1b Description:Calliber II trucks + wheels + Zealous ceramcics. Price (USD): 80 from (64.57 for trucks+ 69,00 for wheels + 40 which totals too 173,57)
Item 2 Description: Full 6374 TB drivetrain with 6x2 tires
Images
Item 2a Description:TB218 trucks (with new pivot cups) with 63mm TB mounts V7 with a crossbar that’s 3D printed and 6x2 inch wheels Price (USD): 160 from (65 USD for trucks + 13.95 for Pivot cups + New Venom 93A double Barrrel bushings 12.95 + 120 USD for Motor mounts + 109 USD for wheels and pulleys Totals to 265,04)
Still got those?
If so, please check shipping rate to Tahiti in French Polynesia postcode 98702. Or if it doesn’t work out for some reason I also have an address in Europe I could use.
I am home tomorow so then I can check it for you. I saw on the torqueboards site thet weigh 0.87kg so it should be do able. But we will see.
I have used the motor on my street board with the 6x2 wheels. But not for that long. I got quite busy with uni so didnt make many mile on it. Guessing I used that setup arround 10-15 times. Before that I used one as a single drive. Then I upgraded to the 2 motors.
No rush dude, take your time. By the way, the shipping you quoted is by regular postal service right? Just asking because if it transits by France, in will end up on a slow boat according to our local post office because of really limited flights.
