My plan is to get around this temporary slowdown is with modular 4S~2P battery packs that you remove and charge at 100W. With 5 of them in a Onewheel that’s 500W charging at most via USB C. While you were at it you could also include the booster for a single input to charge the whole board at once.
While this setup would cost lots more than a standard pack if you factor in you get five PD powerbanks for when you aren’t riding the cost might seem better.
Eh if people can get away with that in PEVs I think its fine in a battery bank.
Side note, that board does not let you actually pull 100w. Voltage drops off really hard when you get close to 5 amps. It’s closer to 90w as specified in the video.
Playing The devil’s advocate I think power banks are way more likely to be extremely close to you/something fragile or brought somewhere like on a plane. I think it’s just a failure any time you demonstrate a battery build to beginners without mentioning cell isolation.
while on the topic. Identical looking ones claim 120W.
https://www.aliexpress.us/item/3256803781469621.html
Since there are no 120W trigger modules, I assume that is really just for charging itself and other devices that support 6A. If you took two of them and plugged them into each other what would happen? whichever one has lower voltage on the 4S input receives current?
Parallel current sharing just means you can connect two of them, so instead of a 20V 5A supply you can gang two up for 20V 10A. Similarly you could get 40V 5A total. Each supply unit has an STM32, as does the LCD control module, and they communicate wirelessly.
Aside from acting as a coordinator for multiple units, the main advantage is thlat you can have a precise and fairly clean supply for testing and lab work while being completely isolated from mains. Normally you’d have to pick a mains powered lab supply that is to some extent referenced to earth unless you go a bit crazy with it, or you run a battery supply. Your options would be usually a USB power bank (very very noisy and loose tolerances around a standardish 5V), directly off a lipo (much less noisy but no voltage regulation) or building your own regulator to run on battery power (probably noisy, definitely difficult and expensive). This solution is still expensive compared to a similar power output mains supply, but wide input clean output and isolation are the selling points
