I would say it could be called a anti-noseroll IE fakie BS pivot.
Since that keeps nose for the creator but allows the language to not get all messed up.
Just think if your rights become your lefts based on your direction or stance.
An how hard it would be to read a map then, or have someone help you park.
It all would depend on how the person telling you to back up is facing.
Then you have to reverse his right to his left since he is facing fakie.
then he says move your wheels right and back up. What direction do you turn?
See how this leads to someone trying to learn a trick and not knowing what the hell to do?
So I been super busy this last week getting ready for eeb-it and not had any chance to get out on the board. That said I did finish a smaller battery to make things a little easier in the future and I have Friday booked off work so if I get chance expect a late Friday entry from me.
Hmm might have to take an L on this one. Heat warning tomorrow, and rain the rest of the week so an extra week wouldn’t help (poor soil drainage). If only I attempted the 180 kickturn while moving last practice!
Hopped on the board a couple of times in the garage while organizing stuff… without moving/rolling I can get about 150° after two attempts…. Going to attempt moving tomorrow hopefully
Try it on grass, the resistance on the rear wheels makes it easier to pivot. Otherwise you might need to time your throttle release to stop you rolling too far during the pivot.
Also, lean forward, I know it’s scary in switch. It’s worth practicing stationary, see how much rotation you can get without moving, the more weight you have forward, the less you have to lift.
Specially watch @NullBlox s video it helped me a lot to get my heavy fukker all around, leaning down and twisting your whole body helps a lot to get over 100° and don’t forget to use your arms
