I recently purchased a Stormcore 60D+ and stuck it in my board with a 12s3p Molicel P42A battery pack in it. I configured the battery settings correctly in the app based on the minimum and maximum voltages given on the Molicel information sheet about the P42A cells (4.2 and 2.5 respectively).
However, the Stormcore app is showing that I’m at 75% battery while the light on the power button is blue, indicating approx. 50% and the VESC Tool app says I’m at 47%. Assuming the VESC is correct, how come I’m getting something so different on the Stormcore app? Is this a bug or am I doing something wrong?
I’m just reading off of the spec chart that reads 4.2 max, 3.6 nominal, 2.5 min. At the current battery charge, giving the app 3.4 minimum reads 47% but I haven’t tested at other charges yet.
