Does anyone know the circumference of the bolt pattern on stooge spur gears?
@MoeStooge If you’re willing to share or DM, I’d super appreciate it!
I thought 42mm but wasn’t sure and am not home to check… also I’m impatient.
This is the dimension I’m hoping to attain.
The 4 bolts or 5 bolts pattern?
the 5 bolt pattern for attaching spur gears to the hubs.
I tried to diension it in fusion, but I’ve clearly done something wrong (skill issue).
Oooo idk… Moe hasn’t taken very kindly to people asking him for design advice lately…
I’m not caught up to any of that. I just know that it make sense to ask the main man first, if that doesn’t work then maybe others can break out the caliper.
You’re good… Just don’t go adding any cylinders to it
