Steel Motor Pulley? D Bore 10mm x 9mm, 15T, 16MM Wide
On the other side opposite the flat. Only needed a couple of mm down with the dremel and 3mm wide, that way I can use either key or D cut pulleys.
Hey I need these same pulleys, 10mm bore D steel, could I get some from you?
Hi. how many pcs you need? I only have the 15T one for 15mm wide belt now.
Two, and the 15T works as long as it’s the steel D sized 9 mm x 10 mm with the flange on both sides, how much would shipping be to Utah?
Hey just checking in
He listed that item here in one of his eBay stores.
Not gonna pay this much shipping, that’s why I’m trying to talk to him personally to see if I can get a price that’s not insane
It’s me again! I been using the same motor gears since June 2023. It’s now 6/17/25. No wear on my motor gears. The only issue is rust. That’s about it. This should standard for ESK8!
Thank you for the update!
