Since I got the best belts for my DIY board. Now my motor pulleys doesn’t last long.lol This kind of suck for long range/heavy users. My motor pulleys only last for a month. No flipsky please. Anyone does custom motor pulley here?
I need:
15T
16mm wide
Steel version
D bore(10mm x 9mm)
I know that Flux AT2 buyers have not had a great experience buying boards, since the original owner passed away last year. Is this site still reliable?
It’s great that you guys helped me but I can’t find the D bore. The dimensions is 10mm x 9mm. Does anyone do custom ones?
I only have aluminum D shape bore pulleys, never saw steel oneon the market. if more people need that I could make some. pulleys only can last a month? dose it possible you belts too tight?
How tight are you running your belts?
normal. Its my weight. 280lbs and 50 miles every sunday.
Can you please make a steel version? I’m a heavy rider(280lbs) and my belts isn’t tight. Where I ride at…There is alot of hills and I ride fast. It’s possible my weight and distance is killing my motor pulleys quick. I already destroyed 4 motor pulleys with this material.
The motors I use is C6374 or the modify version. They all have the same D shape dimensions(10mm x 9mm). I don’t want to buy new motors just so I could use steel motor pulleys. It will be a waste of money when these motors has crazy torque, speed and the 10mm shaft is great for my weight. Also, they only cost $50. I will like to buy 4 motor pulleys if possible my dude. Also, I brought your motor pulleys and your motor mounts before.lol
I know you sell alot on ebay. Make this product possible. Please. ![]()
I have also destroyed aluminum pulleys quickly. I am 100kg and ride a lot. Every day. Titanium pulleys don’t last long for me. Steel pulleys last a really long time but still wear out.
100% We need the steel version for heavy riders. I hope @dickyho design this because I’m this close to start my CAD program and send my design to PCBway.com or xometry.com.lol
custom made need some quantity for each model, like say,there’s many diferent bores 10X9, 10X9.5, 10X8.5,8X7.5,8X7, and if for 14.15,16,17,18,20T pulleys, I need to make a lot, this is the reason, I didn’t make these steel pulleys long time ago. let me ask if I could make some 15T 10X9 bore first…
Let me know. At the meantime, I will continue to use your aluminum motor pulleys. I only have two left before I have to buy again or replace the motors with compatible steel motor pulleys(I don’t want to do this).
how many pcs you need?
Four since I’m building a second board next month. How much will you charge? I know your aluminum version $3.50. Will the cost be double?
7.5us/pc, plus 6us shipping to the States. 36us in total, deal with paypal. OK?
That’s a good price!!! I will buy. Yes, paypal. Are you going to treat it as “product and service”? Please at this on your store near the future.
