You can type kv into vesc terminal and it will tell you, have received motors almost 5Kv off listed.
ok played around with belt tensions and they seem much batter think it was belt tension.
Getting some really off values for speed on my remote and my torque is really lacking
I’m I light guy and running 50amps per side
Yet I’m maxing on the high mode
Thats correct
Looks like the remotes calculating half the actual speed. Guess you could do mental math while riding
Double remote values
hello
trying to connect to my mobile app can someone tell me how to connect?
think i will pay for the app amazing value for money thanks mr vedder
thank you
Literally same issue
Not sure if mine is also half but getting an issue of incorrect speed
how many poles are set in the Remote for your motor? I think remote asks for Poles not pole pairs. so if you are using a traditional out runner it would be 14 poles or 7 pole pairs. for most hub motors it is 28 poles or 14 pole pairs
14 poles
6374 flipsky motors
make sure to check if remote is asking for pole or pole pairs and enter correct value
Ah will check again
Could be that but it comes automatically with 14 so I assume that’s right
Thanks
Yeah @skyart you were right it wants pole pairs
Also @hardunclejohn the remote keeps disconnecting
I pair it to the board and spin he wheels and then the line showing board battery goes off and I can’t spin the wheels anymore
However the board thinks it’s still blinded since the switch doesn’t turn blinking it stays on
Show some pictures of your spaghetti and we might be able to identify something.
Will do about to start an exam so gonna have to wait an hour and a half
If you watch the video
It does what happens at the end every so often but otherwise won’t connect
If you look what happens with the battery bar
Whatever I do it won’t connect to the vesc for more then a second
@BigBen @hardunclejohn anything
are you trying to pair to vesc tool app?
The mobile app it’s the latest version
I get the above error message
