I have two flipsky 6384 motors for sale. They are brand new and never used - I was going to use them for a mountain board build but ended up going for a lower kV. 10mm Shaft. I can include the belt pulleys for these if you like. I switched out the 4mm banana connectors for 5.5mm connectors, so these motors have 5.5mm male power connectors on them. These are sensored and it comes with the sensor wire to connect to an ESC. There are a few small scuffs in the paint from just having these motors sit on my desk; otherwise they are in perfect condition.
Asking $150 for both, which includes shipping to USA.
Did you all miss out on the black Friday sale? Weren’t these on discount for $50? You could have gotten a pair straight from FlipSky for $130 if I’m not mistaken.
Since I do not have an ESC to test these on readily available I have hooked them up to a multi-meter to show that the resistance is low (3 ohm) and continuous across each of the three phases for each motor:
