I’m putting my Lacroix dream board up for sale, because I haven’t been riding it, and I’m building another board.
Speed = over 40mph. It will touch 42mph on a full charge.
Range = the longest ride I did was 30 miles on the dot, and that was using all of a full charge.
This board is ready to go for many miles. Cosmetically it has a few scratches, because it has been ridden, but mechanically everything is in tip top shape and the parts are like new. Nothing has been abused. It has a little over 500 miles of lifetime use, so it is basically just broken in and ready for thousands of miles of use.
The battery is in perfect health, and has always been stored at 3.5v-3.6v per cell to preserve the battery health while not in use.
Parts list:
Lacroix Nazare Supersport 18s4p battery. P groups spot welded by @Skyart of SKP. Battery soldering/assembly by me.
@Boardnamics BN-AT gear drive with 5.5 ratio straight cut steel gears.
Hey all I’m open to parting this out too, if I can sell the deck combo first.
$1650 gets you the deck + enclosure + 18s4p battery with smart BMS, Stormcore 100d, davega, metr pro can sd, hoyt puck receiver, duck handle, and SKP charger. (Pickup or buyer covers shipping)
Where is pickup located? I saw you said you were in SF for a couple weeks… Any chance you are headed up to or around Portland OR anytime soon? How old is the battery, you and skp built it? I assume it’s p42a? Could you estimate mileage for both original board and or on the new battery? What happened to the falcon gear drive? Thanks!
Board is currently near SF. I won’t be coming to portland until August, but I can ship it if you’d like.
The battery is p42a and has 500 miles on it. P groups were assembled and welded by SKP. The rest of the solder/assembly done by me.
The board has around 800 lifetime miles on it. It wasn’t used much before the original lacroix battery pack needed to be replaced.
I sold the falcon gear drive because the falcon drive is not a great design. Bad freeroll. Parts would come loose. Made the rear trucks wider than the front. Fixing a flat tire was a nightmare because you had to take everything apart. The BN-AT are much better gear drives overall.
Putting a package deal out there in case anyone wants a sweet drivetrain to put on a different deck.
Hypertrucks drivetrain package - $1425 shipped for hypertrucks + boardnamics BN-AT 5.5 straight cut steel gear drives, Skyartpower 6485 173kv motors, newbee pentagram hubs, tires, and the full range of hyper truck bushings. The hypertrucks have the upgraded titanium axles from lacroix.
