These are big boys. They’ve only been bench mounted/tested for detection and spin up, otherwise unused/new.
Specification:
Motor: 63100
KV: 180 (rpm/v)
Wire Winds: 7
Max Power: 4400w
Max Amps: 120A
Max Volt: 14S
No load current: 1.9A @ 24V
Size: 63 x 100mm
Shaft: 10mm with 3mm wide keyway
Weight: 1150g
Hall sensor
I actually probably do. I tend to catalog that on each motor I run across. Let me check my notes, if not I can always do a quick detection to get it jotted down.
