Item 1 Description: 10s5p Samsung 30Q battery pack built by Hyperion Systems. BMS is charge only. There is a small hole in the shrink protection because it was rubbing on the inside of the enclosure but it did not damage the BMS. I put neoprene over the area to protect it. It still ripped when I last rode my board a few months ago. I could easily hit 33mph with a single motor and could go 30-35 miles between charges. The battery sat and drained to 27.5 volts, but should still be fine. According to Samsung’s spec sheet, the minimum voltage for 30Q cells is 2.5 Volts. Before this, they were always kept above 3.3 Volts. Price (USD): $175 open to offers.
Are you suggesting that having a BMS is something that only babies do? Cant wait for your shit to catch fire and for you to make a post crying about it.
