SkyartPower.com Webstore (serious)
I will weigh tonight
What is the difference between one of your SKP motors and a generic/stock Reacher? What are the customizations that have been done to optimize them beyond the default?
Our spec is listed at the top of the motor description
Here is an example
I am not sure what exactly Reacher sends to their retail customers, may very well be the same thing.
There are multiple benefits for buying from us.
Fast shipping
Warranty
Support
And we usualy run a sale, like our dispcount code “Spring” 11% off sale. I think by the time everything is said and done you are likely paying only a little bit more by buying from us.
Hi, wondering if anyone else in here has had issues with 5V noise on the SKP escs? I love everything about the esc, but I just can’t find any input that will control it. I’ve tried Analog, UART and CAN.
I know the esc works because it spins fine over usb, but it shows very noisy signal when using analog controller. Viewing signals on the oscilloscope show that serial and CAN have an excessive amount of noise which seems to be coming from the 5V rail (which also has been measured to have quite a lot of noise). I’ve tested all of the input devices on a different vesc and they all work fine.
Let me know if anyone knows of a fix for the 5V noise! Been struggling for several months to figure this out :smiling_face_with_tear:
Did you ask Artem? I have been dealing with him since he had a half a garage set up in Oakland,services after the sale is why @Skyart
He absolutely stands behind his stuff
I replied to your email, will do our best to get to the bottom of it, let me know what input device you are using and we can try to help
if you don’t already have an occiliscope now you have an excuse to buy one. moar tools!! :smiley: :stuck_out_tongue:
Boi i need to update all my threads, as tume allow i will, we have A MOUNTAIN of things going on at SKP.
For now i would like to add this
We now stock 7" NOVA tires! Very excited about these! If you havnt tried them yet, do it for your next set of tires!
you gonna carry the 8 inch version I’ve heard they’re releasing?
Il be stocking 6” but probably not 8”
Do you have any 6001 bearings in stock?
Yes!
Awesome
How much of a difference in rolling resistance do 2RS/DU (sealed) bearings have compared to ZZ (shielded)? I know ZZ isn’t typically recommended for esk8, but do they have a significantly reduction in rolling resistance?
I dont know how to answer this as this is the only bearings i have used in the last 2 maybe 3 years. We hardly ever have to replace them and they do not seem to adversely impact rolling resistance
Makes sense - it’s certainly a difficult metric to measure
Friends we have suffered a terrible blow today.
The cause of this is under investigation, however our neighboring business a cabinet shop appears to have had a fire ignite and cometely destroy their shop. In the process of batteling that blaze a hole was ripped through the wall and flaming debris along with smoke and alot of water destroyed just about everything in our shop. Fire crews evacuated alot of our batteires and only 2 of them appear to have been shorted or caught on fire in some way.
Please see my post here
https://www.instagram.com/p/C_o7weyJRys/?igsh=MzRlODBiNWFlZA==
And if you would like to support we have a gofund me here
https://www.gofundme.com/f/support-skp-after-devastating-fire?attribution_id=sl:e345b488-3cae-478a-a6e6-652440b99bf4&utm_campaign=man_sharesheet_dash_ai&utm_content=amp9v2&utm_medium=customer&utm_source=copy_link
SKP will rebuild…this will not end us :muscle: thank you Fam
I ain’t got much, but i’ll get it started
So devastating to hear, hopefully it gets sorted out with as little headache as possible
Donated
Jimmy you are a beast
so sorry to hear.
