SKP Solo ESC compact HV controller [SERIOUS] SALE! code “AMPS”
@b264 I maxed it out on a MXUS 3k Turbo in my ebike. It did just fine! So yeah 2x of these will roller coaster you from A to B no problem.
Friend is using this on a dual drive scooter as well. Seemed fine. Even in hfi I believe
Solo…
Hall Solo
@Skyart does this have the shunt and phase filtering hardware for silent HFI?
Is pairing to the BT protected by a code? If not, can the internal BT be disabled?
I’m so excited to use mine on the dyno and get some nice juicy data for all of y’all :fire::fire:
@Skyart, seems like it would be great for you to offer a package with the dual top-mount and the taller 3DS enclosure
You bring up a good point! There is not currently a passcode required to pair to the BT. And I am not sure if it’s possible to disable the BT module through VESC tool
This is a 2 shunt design. No phase filter so we are for now stuck with loudHFI
As far as the package with a top box, it’s coming, like really fast, like next week fast.
Will be testing FW6 starting right now
First thing I am going to try are the 2 HFIs
Did you need to do anything special? Neither of my boards would update, just ‘erase timed out’
No, just hit upload and it loaded.
Ive had these sorts of issues tho with all sorts of controllers and usually just tying one or two extra times would make it work. Sometimes I would have to do it from my PC…no clue why. Sometimes it won’t work from my PC but work on mobile
#VESCThings c’mon Al you know this
Lol i tried 3 times. Maybe fw6 needs you to try 6 times
Sounds like maybe you just need to get a couple solos :smile::person_shrugging:
Fun fact, if you own a @3DServisas Heatsinks, the solo and the heat sink under it is a direct replacement and can be installed to fit the same enclosure cut and mount to the same holes…don’t mind my incredible cutting precision on this particular enclosure
I would definitely like to try. They would be perfect for the semendeed.
I have plans to give it a bit of an overhaul, i just need to sell a kidney or something.
Just having some fun, will make one of my long boring videos Tommorow
@Skyart, does the flat-bottomed heatsink of the top-mount dual option have (almost) the same thermal mass as the heatsink on the regular dual-mount? And that then is 33mm high?
It is quite a bit smaller 27mm overall height
See on the left but is designed to sit on Thai large aluminum plate
In testing it has proved to be sufficient even on long rides to not run into thermal throttle issues
