Im looking for an enclosure which will fit a 12s5p flat pack. I have bought an Evolve deck from Vintage Boards. Now I know 10 cells wide is pretty wide, but it is possible https://www.eboardsperu.com/product/evolve-bamboo-gt-enclosure/ for example with that enclosure, but that’s already 180$ to get to my door and thats without possible taxes. My maximum budget is around 100€ Im located in The Netherlands.
Pretty sure @BigBen has a evo enclosure. Not sure what it holds tho.
I dont think that’ll work on an Evolve deck because of the drop
Oh Evolve. I read Evo my bad
It’s pretty similar
I recently was in a similar situation and made my own. Plenty of room for 12s5p on a Paradigm shift deck. It was a LOT of work but I’m happy.
Really don’t know if I can do that
I would encourage you to try
. Enclosures are hard to source and one of the few things that almost anyone can make from scratch. @onebluesummer says he learned how to lay fiberglass making his enclosure and skinning his deck, but it turned out so nice that I suspect he has more experience than he’s letting on
It’s really not much different that papier mache except the fibers are glass (not cellulose) and the glue epoxy (not craft glue). In any case, I hope you can work this out
Ill look into it tonight!
I am using psychotiller altered wedge at I have a 12s5p flat pack in it that is 10cells wide on a drop through deck.
