note: these are soldered before the nickel was welded onto the cells. These kind of joints can only be done before welding.
I think if you’re careful, quick and mindful of what you’re doing, these joins are totally able to be made while the nickel is welded to the cell. I keep a damp rag on hand while soldering, and use it to cool/clean the joint. It also helps to do these types of joins with multiple passes, so that it’s not staying hot for so long. In some instances i’ll use a piece of FR4 between the nickel and the cell body to reduce heat transfer there, and always have some sort of separation or air gap while soldering.
FWIW, i’ve never soldered before welding. I think it’s peace of mind for some, but I don’t think it’s a total no-no
If you’ve got some heat insulation and a super hot iron with a large tip, it’s doable, but you have to be quick, mindful, need good leaded solder, and have a lot of experience imo. I always do these 5cm long continously soldered 8awg joints before welding, and do everything else after welding. As a general advice, I think it’s better to have this kind of joint as a “do before welding” joint
And onto a
fake XT90
no less. Marvelous. No notes.
Don’t come in here talkin smack without showin us ya joints!
The temporary solar backup thing wasnt worth my good XT90S. To be fair the pic doesnt show the wizardry of 2P of 8awg into an XT90 that’s the best I’ve done on that heavy soldering.
Does onto a pcb count for this thread? It’s the smallest thing I have soldered and both with a TS100.
Anything with solder on it counts!!!
I’m gonna expand it to crimp joints too!
Show us all y’all CRIMPS
Ok, so I’ve always been a solder guy.
today i come to work and find my boss has given me the task of crimping (40) AA battery holders with jst xh 2.5 connectors.
Holy shit these are a pain in the ass!
My hats off to you guys that do this on the regular.
My eyes are pretty good for my age. But this has me rethinking everything.
Oh yeah little crimps suck. Looks like you have some good crimpers for the job tho
Hell yeah! They are some banging joints!!!
Eh, gets easier after doing a couple hundred ![]()
I can basically do em blindfolded at this point lmao. I just throw on a podcast, relax, and crimp.
It’s my favorite part of board building
what kinda keeb is this?
/s
Keeb:
This was for a university project close to two years ago now. I asked the guy responsible for the electronics lab for a hot air soldering station, he said he doesn’t have any, I should solder everything by hand. This was a very specific mosfet that opens at a very low vgs, didn’t have anything else on hand as a substitute and didn’t really have time to order stuff. So I soldered it by hand and showed it to him
After that he bought a hot air soldering station… ![]()
Don’t have a picture of it on the pcb unfortunately, I just bent the newly installed legs and soldered them onto the pads. Thankfully the pads were a tiny bit bigger, although not by much.
That’s a solid effort with an excellent outcome ![]()
On pcb scale stuff with a soldering iron I broke a capacitor (I think that’s what it is) off an FS VESC a while ago and did this at a tight angle 8cm from the end of the battery bc taking it out required like an hour of work. I used 2 irons to flow the thing and the pad on the pcb or both sides of the cap it was rough.
it’s power by xt keys! let’s say uhh
good for enigma scrambling if you will ![]()
