Bumping this thread. Are there any new contenders to rival the MT60 and MR60 connectors? I have a build in mind and am looking at MR60s. But if there’s a slimmer/cleaner connector out there I’m down to test it out. Is there even a 6 phase wire connector?
Banana bullets with heatshrink is probably as thin/slim as you’d get, never heard of a 6 phase connector so can’t help u there ![]()
I wish someone would make a connector for 6x phase wires + 12x sensor wires. This is my current solution:
I think @BenjaminF was working on some a little while ago that combined the phase and sensors into one connector. Still would need two, but better.
Starting in 2019 we began transitioning all of our mid and high power ebike kits to use the new 10 pin locking L1019 HiGo connector or an equivalent from Cusmade. This connector has much larger phase pins than the Z910 and is available in up to 4mm^2 thick phase wire (slightly larger than 12 gauge) which has shown to be reliable for up to 100A currents for short times. This connector has 7 small signal lines. In addition to the 5 hall pins it allows for both a speed sensor and a motor temperature signal, allowing one plug type that does everything we want. We are using this plug with the same motor hall and phase colour standards as the Z910, and are using the extra white signal wire for motor speedometer, and the extra grey signal for a 10K thermistor. We hope to see this become a new industry norm.
That’s what the boosted rev was using iirc
