Hey guys! I have a question for this battery build im doing. Im basically dont with getting everything I need for building the battery. But I have basically one question, being should i use 10mm x .15mm doubled , 10mm x .20mm single , or 10mm x .20mm doubled when welding the batteries, Im rebuilding the manufacturer setup (specifically because it has a weird fit) so id like to get it as right as possible. The old bms has a 40a discharge rating also! Any help helps! Thanks!
Ill drop some photos below!
also to note, when doing a bend test with a chip from the ladder nickel it was a little toughter than the .15mm nickel.
