Grip Level 1000
Do a kickflip
i pictured it… Soo much pain:exploding_head:
more reddit gold
it looks like the front trucks are held on using insulation tape - i hope not lol EDIT: phew its only a mock up
I want to see this move sooo badly
I was wondering where my Kool-Aid went…
Y U no use xt90s
it is xt90
xt90s , not the plural of xt90
the green ones? i only had 1 so i put it on the battery cable
its the taped one
Get another one for your loopkey. This is where the spark happens.
it was a bit of an afterthought, i was hoping to avoid loopkey but couldnt turn it off
You don’t need one, vecs uses almost no power when idle. Will only lose 2% batt per month.
Just use the push to start feature. Ur build looks so legit, no need for loopkey.
wouldnt the battery screen use a lot of power tho?
Nah compared to motors it’s nothing
I wouldn’t recommend leaving your board on all the time. There have been enough users that forgot to turn it off and fucked up their battery. Get a xt90s and be safe.
@zZoKo don’t listen to @xsynatic
Using a loopkey means introducing more copper to the system. Longer copper = higher resistance = more power wasted.
Build like a pro, don’t use a loopkey and glue your enclosure shut.
Or a QS8 ![]()
I didn’t use a loopkey, just connecting the Batteries when i go out for a ride and plug it out when i’m done. But i use lipos without a BMS
I hope @zZoKo recognizes sarcasm
