One set includes:
Two motor plates
Two clamps
M5 hardware for the mounts and M4 for the motors.
Features: Compatibility - MBS Matrix III & II and 22x22 mm trucks (e.g. Apex air & Moon Luna) Mounting - strong clamp down with one M5 bolt (+ optional setscrew) no fiddling around Finish – Raw, shiny as machined (no anodising) or Black anodised Material - 6082 T6 Aluminium
Weight with hardware - 440 grams Centre to centre distance - 100 ± 5 mm Mounting angle adjustment - 30 degrees Motor pattern - 44 mm (most common 63xx motor mounting pattern) Support - idlers (quick adjustable M5 captured nut), TPU bump cover and cross brace
The design has been tested for over a year now and has been fitted on MBS MIII, MII and Apex airs (see
pictures of the first version below)
The mounts are produced in house in The Netherlands and the manufacturing of this batch will be documented in this thread. You will be able to see your set go from raw aluminium to the final
product.
You can find more info on the manufacturing here and on our Instagram:
