Done.
@jeffwuneo you should change the original post to reflect the 75kv 90mm urethane
Just to be sure, if we pick 90mm sleeves, the motor still come with the 85mm sleeves ? Or does the 90mm replace the standard ones ?
Also Jeff, will we be able to buy replacement sleeves in the future? This is very important
It come with 85mm. But if you choosing 90mm it also come with.
agreed.
To Benās point friends: this is (still) a hub motor.
Weāre stoked to see how Neo Switch hubs work on tons of platforms including the Neo One.
We think Neo hubs could help lots of us; Raptor2 owners can stay relevant, upgrade their sleds to best in class TKP like @Psychotiller HeXLs, or RKP with @Boardnamics and adjustable base plates for any drop-through shenanigans.
90mm sleeves & curved magnets in the Neo can should ride better than almost any other hub motor out there.
Cronins under the Neo One should be stoked on smooth roads, thatās a very good idea.
For later after testing, if wanting bigger wheel, we can making 60kv and 100mm PU sleeve. But may be too much heat for safe riding. So we think 85-90mm is best for maintain good life.
Yes, and we plan to making proper mould in time. We also list extra sleeve on form now so can getting more now.
Survey done !
I already chose 90mm sleeveā¦ did you add more after i filled it out!?
No, is right. We add 85 and 90mm option for sleeve if want. We start make PU this week and we place order to factory by Wednesday. I let know time when we speak them. They deliver motor to my factory and we test each first and install PU, then seend for you friend.
Thank you friend.
Wider is better! Thankyou Jeff!
We extend PU to be align with face of hub. This giving support and can stopping crack. Do want square edge or round edge for wheel?
I prefer rounded because of the traintracking affect you get with straight edges
I like squareā¦ people can always sand down the edges if they want them rounded
in for thick/wide thane
Probably a newb question, but this is just the motor,wheel for sale right ? No trucks ? What trucks can I put these on?
@rey8801 took a shot on a custom 60kv wind with mad hubs. They didnāt work at all. No torque, extreme heat.
Check out Loaded unlimited to see how it works.
