6374s work on that setup, its tight, but works.
On thane, was such a fun ride
Not positive it’ll fit on 2.8 gearing
Only Maytech 6374s will fit forward mounted with Savage’s modification. With other motor brands, you’ll have to go shorter.
Nope, 2.8 requires forward mounting the motors.
I agreed with my friend @zero_ads and I’m going to try to do a test, with reacher 6374 engines ,
how many cyliinders?
Kkkkkkmm motor bro
Heads up guys……
One of my press fit motor plate mounts started to work its way undone. In the middle of my commute home yesterday I stated hearing this crazy grinding between my pulley and motor mount plate.
This afternoon, I removed the mount with a hard rubber mallet. Sanding it down now and will install with JB weld.
If you have the version of the trucks with the press fit motor plate mounts, keep a close eye on them.
Yep, I experienced the same issue and described my frustration with the design previously in this very thread:
This is why I think it’s very important to use the handle bar to keep the two motor mounts locked together and not sliding outwards. I’ve also considered getting a long M3 rod and some nuts to lock the two press-fit plates together… Kind of an ugly solution though.
friend which wheel do you use? I see you managed to adopt her on M1
Infinityhub from @surfnacho. But defiant and Hoyt now have some small Kegel pneumatics which might work
Thanks for the tip, I had my eye on these from Defiant but pre-order is going to take a while, I see that Hoyt is the best choice
Can confirm.
I’m considering doing the same thing now as three out of the four handle bolts sheared on a ride today…
Unless anyone has a spare set of mounts floating around that I could buy?, I hear @Savage1 is out of the game…
@cherryflavouredpez Ya, I’ve been out of the game for around 6-7 months. I have extra motor mounts
I do also have 6 more sets of the trucks themselves, that I will get a few of them black anodized in the coming week.
Hi Phil, I saw that you posted here that you have engine mounts for sale, I’m interested!
