I think this would be super cool to see in a production truck. The only way this is achieved currently is with aftermarket mods no?
Don’t trip poppys have them.
It’s something LDP and slalom riders do to bennetts
I did it on my LDP board. Seems good. Pretty easy but dremel and epoxy is ghetto.
No, but that looks cool too.
Kinda like the ronin queen pin (ish)
The one used in DTP seems a lot smaller.
All trucks that are interesting. Steering mechanisms for a board.
kinda a place to talk about that here, i would like a split off for any axle spherical pivot having truck.
Yeah that’s the plan. Have a concept for trucks similar to liquid fyre trucks with many improvements (imo) for esk8. Maybe we can have something for testing early next year.
I think 250mm hangers and 220mm hangers are a good place to start. How about two different options or baseplate angles? It would allow those of use who want to run TKPs on both ends a little added stability.
I’ve been running the standard surfrodz baseplates with mine, dewedged 5 degrees in the rear and it’s been awesome
I think another thing that would be cool is to use long bushings in the boardside position. This would allow for a little bit more movement and decrease the tuning radius.
With the use of a spacer, a standard height bushing could be used for those who want less motion.
You could even use a longer bolt to allow for the use of a long bushing in the roadside position. Could make for a carvy ride without the need for DKPs.
Tkps are pretty damn carvy even with just standard size bushings.
True. It just adds another level of adjustability without too much work. I really like DKPs unlike most people. I use Chamber Trucks and they use a tall bushing in the boardside position. I think it makes it feel carvier. If you want less carve then you can used a spacer and standard height bushing.
Maybe optional length kingpin
Small update on the progress of these…
Base plates are done. Hangers have been ready for axel end machining for a few weeks now, but I’ve been trying to come up with the best end profile to accommodate for some sort of a standard. This has been difficult as I want to accommodate for as much interchangeably as possible without compromising on durability .
I felt that a 22mm square would be a good start. @ApexBoards but trying to make that fit the BN M1 gear drives, (not AT).
The biggest challenge for this, is my axel design. It will be a 10mm axel, but with a 15mm flange screwing against the hanger. (I will not stray from this).
I’ve got a design for a belt drive motor mount 22mm with 6mm chamfers that could also replace the hanger mount on the M1 gear drive.
More info coming….
I look forward to any feedback, suggestions, and criticism.
Axel end machining is happening tomorrow!!
I like how you just did Kevin’s job for him. You get a gold star. Unless you’d prefer it raw of course. XD
Nice dude! Getting keen!
I think if you made your clamp the same as Kevin’s would be ideal! Is there enough room tho to accommodate the flange and still be strong enough?
hmm would it make sense to machine a BN 220/270 hanger profile to 22x22 AA adapter?
Bearing options are not great for 10mm axels. I love the Zealous type of bearings with built-in speed rings and spacers. So convenient. I haven’t seen an equivalent for 10mm axels.
I would much rather have 8mm, though I can imagine strength could be an issue.
Anyway, this is minor. Great progress. Can’t wait to test them out.
He could offer some custom spacers for 10mm
Or maybe @Anubis could hit up the Zealous factory (since he did get a custom batch made once) to ask if they’d be down to produce a 10mm version for the esk8 community?
There’s a number of 10mm axles in regular sk8 too. Surprised that they aren’t already out there
