Hoping someone can tell me if this is okay before I mess anything up
I have a 12s4p P42a 4200mah battery on board, and i want to run a 12s6p brick pack as well for extra range, using Lishen LR2170LA cells 4000mah cells - both packs are new.
I have used two charge ports simultaneously and others have successfully as well. I’m not going so far as to say this is “safe 100% of the time” as there are a lot of variables.
But I would feel comfortable plugging in two lower-powered, high-quality chargers at the same time.
so its like running a 12s10p? Its just grabbing the same amount of juice from each battery pack?
Just trying to imagine how this thing performs - so it’ll just decrease the time that my 12s4p pack drains? the 4p is the pack that my stormcore reads to my ride-tracking apps
and even tho they are different cells I guess they are very similar in capacity so they should be no problems?
“Should” is a great word but one we really can’t use here.
But taking all the necessary precautions, and keeping an eye on things as the packs age, can help to prevent any safety issues from popping up.
Capacity differences are really just a performance concern, not an inherent safety issue. The lowest capacity p-group determines the performance (range) for the entire pack.
I don’t think this is even possible unless the multimeter is internally fked. I’m trying to think of how you could do it with a working multimeter and by only connecting the probes to the battery and I can’t think of any way that could happen even if you wanted to short the battery with it. The probe tips are too small and if you can touch both terminals of your pack with one probe then your pack would have already fried itself. the distance is short enough that the current could arc through the air
Well you could either have it on current measuring mode, instead of resistance measuring mode, or, the more likely option IMHO, is you could accidentally touch the two probes together (to each other) while they are stuck inside the female XT connector.
Either of which will probably give you a very, very sharp reminder on how extremely important it is not to do this.
@Crate I would recommend not connecting these in parallel. If you want the jump pack, I would treat is as a second pack and set up some kind of switching system with loopkeys or other, to change between main pack and jump pack.
Keeping everything separate for charging and discharging is just simpler and safer IMO. I think @dskate did something with switchable packs on one of his builds. Spruce moose?
I did. I had two 10S3P packs inside a wooden enclosure on the deck. I wired it so I could swap a loop key from one port to another on the enclosure and switch between the batteries. Worked great. Here is the diagram for how it was wired. I ended up putting a few of the elements in different locations (lcd battery screens, didnt end up doing the underglow etc) but the wiring followed the layout shown here.
I really like the dual loopkey input with single key design. As soon as you feel your battery start to sag, you pull out the key and plug it into the other pack. Boom - no sag!
Yeah worked great! I’m considering adding a similar design on my current build so I can do an additional top mount auxiliary pack for longer rides. Then be able to not have it when I don’t need the extra range.
