I’m new here but longtime E-skater. (Boosted, Revel). My Revel died, won’t turn on. So I’m stuck with replacing the ESC with something, VESC? I’m looking for suggestions.
Thanks
I’m thinking a Puaida
I don’t know if Revel wired the BMS for discharge.
Have you determined if voltage is making it to the ESC?
I have a pre 2023 Puaida ESC.
I took it out of service because the remote was randomly self disconnecting, requiring coasting to a stop with no brakes, and cycling the power button to continue.
Recently, I put it back into service, with No power button, plugged into the ESC and have yet to have a disconnect in about 70 miles.
I’ve been going Crazy trying to find a remote that will pair with me Revel kits…The skate batteries are doing fine, but the remotes are barely holding a charge! 2023 Puaida you say?
Yes, Puaida …could be the same 10s ESC hub motor Meepo sells, IDK.
Could look the same, but be programmed differently.
Another 40+ miles with no remote disconnects.
Twice, push to start didn’t work, and remote was not connecting.
Had to pull loopkey, and reinsert, then all was good.
If it failed today, Id likely order the newest Puaida esc version for easiest swap, and added functionality of the smaller remote, and claimed stronger brakes.
Have you already tried to replace the battery in the remote? Or is the remote itself no longer up to the task?
Replaced Revel ESC with Puaida ESC and remote. Had to splice motor wires for the right connectors, but got it all back together and it rides great!
Any chances you can take pictures of what you used and where you had to make changes in the board please ? I’m a visual learner and I don’t even know how to take the motor apart on my revel kit
Hi Murdoc, I am facing the same issue as Torres. After the Revel remote died, I would like to use a Puaida ESC. Can you assist with an image how you spliced the motor wires? Thanks so much for your help!
Sorry if I’m a bit late, but I took a Miles phantom esc and wired to the revel motors, and was able to use almost any hobbywing remote so far.
