I have read some threads pertaining to 12mm and 15mm belts. In what situation/use/build is 12mm best to use? In what situation/use/build is 15mm best to use?
Thanks in advance!
Thanks in advance!
Either is fine, I wouldn’t sweat about it.
Indeed. Now i’m pushing almost 2 years on a set of 15s. I ride every day too. Its all about alignment, good parts, good tension, and avoiding loose, belt hating bullshit on trails.
You need to look at a system and balance the components.
12mm is fine on a dule motor built reduced drag with out having skipping and snapping issues. When applying the brakes is the time demand the most from your belts I’ve ran some big gear reduction for max acceleration and a properly aligned and tensioned 12mm belt doesn’t snap or skip. I can shread a 9mm belt in a couple of minutes
I’d use 15mm
Single motor builds
Insane motor and battry build
Off road MTB builds
Running baggy belts that are not alined
On a urethane build I like to run a 13mm flanged motor pully (super hard to get your hands on) 15mm wide wheel pully. This means the motor pullys keeps the belt Alined when things flex and the wheel pully has some play and won’t run part off causing increased we are on one side of the belt.
