I used clean breeze on my cells. Am I fucked?
Beautiful picture
I saw someoneâs post about $25 tire that doesnât last long. And it reminded me of this post on the other forum. These â6x2 fastwheelâ tires are dirt cheap and last a long time(~2000km based on my tread wear rate, I have already done 1000km). We shouldnât be overpaying.
link1: https://item.taobao.com/item.htm?spm=a21wu.10013406.0.0.2d29317egeiJ2t&id=558643804538
link2: https://item.taobao.com/item.htm?spm=a21wu.10013406.0.0.2d29317egeiJ2t&id=564165887103
How do you wrap the wires coming out the motor like that? Is it just heat shrink slid over the mesh and into the holes in the motor face?
Is there some easy way to convert the site to English to make ordering possible for me
No, not really. That should even give you some extra freshness
You shouldnât charge any lithium batteries below this temperature, whatever your BMS. You will damage your batteries, unless you charge at a really low rate, something like 0.02C.
charging is one thing which might not be the problem here as he will do that probably at home anyway.
the question is, will the components on the bms get damaged by having the bms hooked up at temp below 0. I mean the bms even in charge only is always switched on even if not actually charging and balancing.
Shouldnât the heat generated from use keep it toasty enough? Enclosures are generally well insulated
you know @b264 rides 365 days a year, even at -25 degree celcius. no way the enclosure can hold the temp over 0 degree than. ok, maybe with a bit moooore power and attached to the esc heat sink it could work out
Roman youâre such a fucking chiseled Russian god. Iâd pick the sweetcorn out your poo allllllll day.
I love you too
@jeffwuneo did you make this deck? If yes are you selling them?
If no where can they be bought?
It looks like a bamboo skinned Haya kicktail
Nah itâs totally different. Thought it could be a MOV-E deck, but itâs too small to be that either.
Hi friend. We make deck by CNC process. Is soon sale.
