I think thane might be better and @RipTideSports should integrate it into the Tunnel Riser :yum:
dat some repugnant BS
a new member on the forum asked if I could take a look at his halo board 2. Not only was the esc fried, the battery shorted out because the board wasn’t properly sealed and iron shavings shorted some P groups. I immediately dropped it off at work because they can dispose of battery waste :sob:
building him a new pack as we speak
doing gawds-work… thank you
If only a bank was on that list for a large amount, this whole situation would be taken more seriously.
This, hooked up to main battery. Steps voltage down to 12v :+1:
I shudder to think how much it would cost to CNC this shape… :joy::flushed:
That shit is bona-fide terrifying
@Accrobrandon what trucks are you using on that beast mode hummie
Im a man of simple pleasures lol torqueboards ftw always!
If this is because temp sensors, mine doesn’t have those.
I’ve been monitoring motor temp by touching the cans, and they’ve never been more than slightly warm.
I’ll probably need to get an IR thermometer to measure stator temp at some point though.
@Accrobrandon also, are those 8in UnTrampa wheels? I’m surprised they fit so well on the hummie
Yeah no.issues…maybe a hard lean for a u turn gets bite but for higher speed riding unless you’re super heavy and going for hard carving I dont think its likely you’ll get wheel bite under moat riding conditions…
If u have a 44 plate then yeah yur gonna have to redrill and slide back a 1/2" max
Funny imagining it breaking like that from cutting just some stranded wire. Imagining your face is pretty funny too.
meant for plastic… originally designed to cut zipties flush without those razor like shards like normal dykes make…
I call USER ERROR…
Welllll I was maybe using it to cut inch wide braided copper ground strap… apparently it wasn’t up to the task this time.
I salute this fallen soldier.
Anything I needed cut, he was there. But now I have nothing. Nothing.
Tis merely a suggestion
and yet it failed… hmmmmmmmmmmmmm
All good things must end eventually, sadly it only lived 3 months :sob:
It came with my ender 3 to cut plastic filament, so ya, u right lol
I’ll give ya 3 guesses what that tool is called in the industry… tool industry, like snap-on, matco, etc…
if’n you fuck 'em up and don’t care, harbor fright sells them at like 2 bux a pop… the snap-on ones are like 40 bux…
go to harbor fright and buy 10…
