maybe thats the hanger material?
maybe …
but they say alloy axle on the website…
And Rene is making it full AL7075.
Oeh that looks good! Where will u get the drive manufactured?
not eggzakery… what you are feeling is cogging effect on the magnetic flux, showing not only how strong the flux field is, but also how weak it is… some like this ā€œfeelā€ as they ā€œthinkā€ this is desirable… but it’s not, and it’s not as efficient as a flux field that is better directed and managed, and does not exhibit this ā€œcoggingā€ feel…
Looks like a sweet design, but what plastic are you using? I would worry it will melt when soldering
solder first. then push terminals thru the back
EDIT:
Or better yet, push wire thru printed housing, solder terminal away from printed part and pull the wire to pull the terminal into the housing… brilliant!!!
Its just normal pla for now, i think im gonna use nylon in the end… and yes, like @kook said, i have to solder first and then push and glue the bullet connectors in :smiley:
A mockup of the legendary MR90 emerges from the imagination
I was asking not if the shaft was keyed for the pulley — but is the shaft keyed for the rotor (with the magnets on it)? Because rotors slipping on the shaft has been a consistent problem with many different motor designs/brands. Grubscrews are shit.
I was litterally trying to come up with a kinda MR90 since yesterday, dude that’s awesome !!
Did you test it ? Will you share the file ? I like that! :grin:
No, I didnt test it yet. But I think that these 5,5mm Bullets are a bit overkill for my 6384 motors :sweat_smile: When everything is finished, i will upload the design to thingiverse, but you would need the exact same bullet connectors to make it work :confused:
It’s alright I can sacrifice a pair of XT90 for science :laughing:
You have eventually a step or solidworks version?
I have 6.9mm bullets waiting to be treated the hard way like they deserve :fire:
XT90 ā€œonlyā€ have 4.5mm bullets (inner dia.) :grin:
Not yet, i have too much stuff to do right now :sweat_smile:
Aaaaargh my life was a lie! I’ll commit to reset my mind by watching @Sender last sale topic. BRB.
I still can’t make made my own GD :weary: :money_with_wings: they ask too much.
I will go with 3Dsas again (by the way, this is the kit you can see on my 3d renderings).
But when we will be able to move (we should make our house-warming this WE …), and set and use my cnc, I hope to make mine at home :slight_smile: … after more than 3yrs of upgrading drawing (thx to everyone here ^^) it will finally be time !
Where’s the skateboard or gear or anything esk8 related?
In reply to Matt’s build, saying it looks yummy, just as yummy as that Snitchel roll
Put some bearings or XT60s on it at least :grin:
FB_IMG_1435284454745
I’m askeered about how big your nuts are…
