i reckon they hadn’t conformal coated the wood
Yeah. That is gonna buff Right out…
I helped TB & Kaly out with both those PCBs, but sounds like you guys already figured out your other questions.
I believe Ernesto uses it in his 2.0 board, and the TB one is to be announced.
what deck is that?
It was a deck made by a friend of mine. Was 10 ply Baltic Birch if I recall correctly.
you look like you weigh as much as one of my legs. This is why I get Tim to reinforce my decks.
Why is the load+ conected to the charge+?
No canbus connection
Thank you, I rerouted the wires and messed that one up… load+
The canbus is there?! the grey and blue wire, are they also the wrong way around?
I am tired
EDIT: The Load+ is fixed
Doesn’t link to the diebiems so it can’t communicate to the vesc
Missed this.
175A M5 Bush Terminals. This is a prototype pack for a modular p-group battery building kit I have in the works. Going to come as ‘add-your-own-cells-n-weld’ kits for 10-18S or as prebuilt 4/8p p-groups (40T Samsung 21700). I’ve got custom stamped 0.3mm nickel tabs+ premade 10ga jumper cables inventory incoming.
Makes for a simple, serviceable, easy to build/rebuild/scale battery system.
I’ll have a couple beta kits up for sale at a discount in April.
Bruh, you need some MG Chemicals #419D right away! Give the new ESC a very, very thorough treatment before it gets wet
WTF!!!
I think I like it!
Rest assured I’m going to do something profoundly dumb with it.
I certainly hope so!
I got it as part of Seanathon’s dowry.
Does it have 10mm shafts?
would you keep the hubs? make a custom pulley or adaper
This looks prime for a better than a lacroix title
