bro same, I would choose the 1 ant. And it would give me nightmares
I like Metroboards. They worked with me when my battery crapped out on me. I also like the design of these builds.
@BillGordon, time to start a “Costumer’s Most Valuable Esk8 Manufacturer” tread. You gotta ask about the important aspects: Costumer Service; Quality; Bang for the Buck; Consumer Satisfaction, etc, etc, etc. You are the poet!
Strong is relative still,
A tarantula is a heavy lifter. I can attest this. I confronted one while climbing a cliff in my native country. Pinned down the animal to the ground with a small inverted Y branch. Mfcker was strong like you cannot believe. Little branch bent almost braking with this beast trying to uplift with all her strength. I realized then how strong this beast is. You feel her power. That’s why they say if they were proportionally the size of a human they could lift a semi truck. Powerful animal.
Can you share more information about this build? Thanks!
@rich
🖼️ Pictures and nothing else!
Looks like there is not much space between gear case and tire. No worries that the tire will rub against the case at some point, like when landing after a jump?
Yeah it’s close but there is no wobble so it should be fine, also I’m not the first with this setup. Between tire and bolt is 1mm space :laughing:. Let’s see if things get stuck, going for my first ride with 9" right now, so stoked :yum:
So 10“ wouldn’t fit than I guess :sweat_smile:
Have a blast and let us know how your test ride went!
That is such a sick ride man, jelly! have fun dude!
You know what changes people when you step in it without a shoe.
whoa!! that my friend would definitely change me in the worst way lol
I have the thin, cheapo trampa bag. It is great for transportation and storage of the board without getting mud all over the car or apartment. But the cheap bag has pretty weak handles, I am afraid they will rip off soon :sweat_smile:
The Muck off bag?
Exactly, forgot the name.
Well the 9" are really great but the Matrix II trucks tried to kill me several times. Each 2-3km the hangers get very loose and the kingpins need re-tightening. Furthermore I experienced the worst and most scary speed wobbles of my life and had many crashes today. Need to investigate further what’s happening but I’m quite disappointed with the trucks. Strange that the Matrix II trucks with same shockblocks run great on a different board, that’s weird.
I was thinking it would tend towards unintentional manual and other tricks!
I’m guessing this is because @Kug3lis did not want to ride around Japan with trucks that said “fat boy” on them, in fear that someone would confuse it with you know what…
Well u kinda close enough but NOT :smiley: It was called Fat Man and Little Boy :smiley:
If you ever make trucks with short hangers they better be called “LittleMan” :slight_smile:
Thank you for the sanding tip. I did it and recoated it and it’s perfect now. I can now touch it without having to brace to get cut. Awesome ^^
Would you do more than one coat after sanding?
