Dickyho 6374, had to tear them apart to change the phase wires as they were only 14AWG. In this process I ruined most of the bearings and those needed to be replaced. The replacements don’t have a tight seal around the shaft so there is some sideways can movement. A couple of the windings were torn apart because the wires were epoxied to the can and during disassembly I ripped them off. Will be buying new motors to replace these as they are now basically useless. You live and learn
Your $2.50 calipers?
But for real, I’m measuring 18.13-18.15 on my red 50Ds, and they fit up just fine. I’d suggest wrapping the pivot cup in teflon pipe tape 2x and it should help the fit. Unless your calipers are garbage and it’s larger than reported
Ya I’m sure it’s fine to ride. Just shitting machining for a “precision” part
tbf measuring something like that is a pita
When I was a kid we had to measure our pivot cups using only a small rock and the sun at noon.
You don’t know how easy you’ve got it with your fandangled digital calipers.
My Mom says hi dude…
Tell her my KFC MunchCard is empty.
I think @torqueboards has died. He has been wanted for weeks.
Thankfully his wonderful stickers will be forever with us
jokes aside i do really like Dexter and his products
Looks like a job for JB Weld. This isn’t a hard problem to fix. Hold my beer.
A hard problem to fix is POM gears that have broken teeth. Those are the real problems. You can’t fix those with JB Weld, you have to order more of the same plastic parts from Lithuania.
Gross 5char
Hmm ok so what I think the easiest thing to do would be to cut the middle of the wheel hubs out and put a hub motor in there.
I’m keeping this analog. The way the wheels lean makes it impossible to add a motor.
The nose/tail shape of this deck looks stupid. Sucks that the hole pattern is not standard
Wouldn’t it be theoretically possible to replacing those struts on the hanger near the wheels with a motor mount that swivels? I realise thats not a very practical solution just wondering if it’s possible.
$239 is a lot but it includes those nice wheels so whatever. if you make your own deck and stuff which you as well if you are making a custom drivetrain.
@Mikenopolis were you saying that it wouldn’t work with a direct drive/hub motors? Or that you couldn’t fit a motor mount and motor anywhere near the wheel.
