4s4p? what kind of range are you getting?
A UPS in a server farmâŚ
itâs off the grid solar storage at a house in trinity county
https://esk8-news-objects.s3.dualstack.us-east-1.amazonaws.com/uploads/original/3X/3/2/327137bb29de08680e95616a4043c8ca5ea7b240.jpegI started the OEM test cube, but decided that was a waste of time and quit that. Started a dickasaurus for my first.
So far so good. Quality of prints kills fdm. This isnât even cleaned up or cured.
As always, I admire your process.
Looking forward to seeing it
esk8 Rorschach Test
what do you see?
What happened? Why did you have to pull all those welded tabs?
I think it was due to a wiring correction we wanted to make iirc from reading his thread about the rest of that build.
At first I thought I was looking at his tutorial and that was just one weld test.
one big weld test
I tore the whole thing down
It all worked⌠it just sucked
Poor design of the connections was the biggest issue.
you can make a real good post about how to clean welds off cells now .
haha and you made a point about drawing it out on a picture before.
If this tale says anything itâs that this shit is hard.
In all honesty Iâm not much of a planner i just do shit and hope for the best.
If it doesnât work out, I fix it lessons learned, no fires started
yet.
anything is possible, achieve your dreams donât let anyone hold you back battery I believe in you!
Haha battery building is definitely not one of my dreams.
Dude. I feel ya. Built that LiFePO4 pack the other day, and not enough output. Spent many nights and resources to get it done too, and with little ones my build time is limited.
That sucks man. As if building shit isnât time consuming enough. Rebuilding is shit!
I was hoping to have this done today so I could spend the rest of the week working on the c3p0 and getting the flexibms into it.
Cells are cleaned, nearly chewed through a whole little dremel bit, but it did a good job.
I used the large tan stone wheel and it leaves a really flat and smooth finish, might be easier than the burr but?
Mine is caked in solder
